Ok, thx for the clarification. Then I must look elsewhere.
It seems there is an error with the height detection.
When it tries to level, the #core is the first it tries to touch the build plate with, and it lacks maybe 6-7 mm in touching.
It just moves up again, and then tries with core #1. It then makes the following error.
I have just manually adjusted the height with the card, so the settings should be ok.
This is a know design flaw, the fix is to buy an S7.
Update.
I tried cleaning the capacitive sensor and re-installed the silicone cover underneath the nozzles.
Worked 1st time hereafter. I hope it continues. 🙂
sometimes the cause seems to be a broken wire on the front fan.
- Solution
There is a detailed guide for resolving this issue.
https://support.makerbot.com/s/article/1667410781005
2
Enigma_M4 125
there is no spring above the -static- printcore #1.
So there's no spring missing.
Pushing up the printcore while levelling is to a certain grade normal.
Your auto-level issues must have a different reason.
Regards
