How do I change the Default Temp for generic PLA in Cura 5.3.1?
ednewbold
Go to solution Solved by ahoeben,
Posted · How do I change the Default Temp for generic PLA in Cura 5.3.1?
How do I change the Default Temp for generic PLA in Cura 5.3.1?   I have an FLsun v400 and need to up the temp a little for both the material and the bed.  Thank you.
    Posted (edited) · How do I change the Default Temp for generic PLA in Cura 5.3.1?
    Hi @ednewbold,
    Just go to "Preference" menu in Cura, then select "Configure Cura" and seclct "Materials".
    You will see this menu:
    You simply have to duplicate the material with the properties you want to change,
    then you have a copy written in "Italic" that's show this is an editable copy.
    Edith: The above statement is wrong!
    In here you'll see that I've changed the printing temperature to 210.
    Thanks
    Torgeir
    Edited by Torgeir
    Edited text.
    • Solution
    Actually the italic means that this is the currently selected material for the current printer/extruder. There is only one italic material at any time.
        • 27 replies
