GregValiant 1,110
Torgeir's project sliced fine for me as well.
Check the settings "Outer Wall Inset" and "Horizontal Expansion" and "Horizontal Hole Expansion". They can have an effect when features get close together.
1
Torgeir 228
Hi @cura0815,
Welcome in here.
I've tried slicing this water can using spralized "mode", single wall and 5 layer bottom.
There is no issue with extruder jumping from cone tip to water outlet place (front of the can) as far as I can see.
I'll think you better save your "Project" file, containing; your model, Cura version with all of your setting for the model, then someone will look for sure.
Here's how detail what it looks like in the gcode viewer Cura 5.3.0:
Here is my project file (for printer UM2E+):
UM2E_watering_can2.3mf
Thanks
Torgeir
