On 7/10/2023 at 7:22 AM, Dustin said:I would advise using Digital Factory, its designed for this sort of use.
The free tier should meet your needs i think?
Im using the digital factory already. i can send files from both computers. thet problem arises when one cura install doesn't have the materials listed that are currently loaded in the material handler. When the file is sent to the printer, it fails since it was expecting a configuration that doesnt exist in the printer at that time.
To put it simply, I need both cura installs to match, including any custom profiles and/or materials.
it would seen to be a rather simple feature to provide, basically uploading whatever is in the machine to the cura install.
Dustin 144
