Is there a way to add thumbnails to g-code after it has been generated? Maybe a batch method?
Go to solution Solved by GregValiant,
Posted · Is there a way to add thumbnails to g-code after it has been generated? Maybe a batch method?
I know I can create a thumbnail as a post-processing when creating the g-code but is there a way to add the thumbnail after the g-code has been created?  I have a lot of g-code files I would like to add thumbnails to but don't really want to re-process all of them.
    Are you talking about a ufp file?  I don't think it's possible to add a thumbnail to a gcode file.
    No a gcode file.   I guess I would have to individually re-slice them.
    We must have different definition of "thumbnail".  To me a thumbnail is a small photo associated with a file such that on your computer you can see a small image related to the file.
    Same definition.   Typically the thumbnail can be generated when slicing into a gcode file.  That image can then be seen within Octoprint for example to see what the model looks like rather than just text.
    gcode files are just text files.  They can't contain images.
    ufp files contain lots of meta information including gcode, thumbnails, and other meta information such as what printer you sliced for, what nozzles are needed, materials, etc.  Maybe you mean ufp files?
    I think you must mean ufp files.  You can definitely edit/change the thumbnail in a ufp file.  Octoprint (or I guess printoid?) will display that thumbnail.  Here's how you do it:
    rename the ufp file to be ".zip" instead of ".ufp".  If you are on a windows computer it may be hiding the extensions.  Google how to show file extensions on your particular version of windows.
    Then double click the zip file and you will see the directory struction.  It's easy to find the thumbnail as there are only a few files in there - replace it with a file of the exact same name that you want to be the new thumbnail.  On windows I think it's best to extract the entire ufp into a directory structure, change the thumbnail, then zip it back up with some utility.  I don't use windows much lately but I think windows will zip up a folder if you right click on it?  Or you can install winzip or other app that makes zip files.
    Finally rename the .zip extension back to .ufp.  Now octoprint will show the thumbnail.
    My description may sound complicated but once you've done it a few times, you can change a thumbnail in about 5 seconds.
    This is an example of a gcode file created by Cura which contains a thumbnail which is displayed within Octoprint.
    CFFFP_SmallPlanter.gcode
    • Solution
    "... is there a way to add the thumbnail after the g-code has been created?"
    Not without writing your own program to convert the images to an ascii format that could be pasted or added into the gcode.
    The Cura post processor takes a "snapshot" of the build plate in Cura (by recording all the pixels of the screen??) and translates that mess into text.  You would need some sort of image of the part and the translating software.
    Oh!  So there *is* a way to put an image in the gcode comments.  That's a new feature I've never seen before!  I don't know what algorithm they use to convert an image into ascii data like that.  It looks like base64 encoding.  I think the 300 300 is the image size (300 pixels square) and the big number is the number of bytes or maybe characters that follow.  Then it looks like base64 encoding (you can google about it) and there are utilities and web pages that convert files to and from base64 but you also have to add the comments and carriage returns and so on.
    Posted (edited) · Is there a way to add thumbnails to g-code after it has been generated? Maybe a batch method?
    None of these scripts will be very helpful. They are meant to be run from inside Cura, and it is no small feat to run them standalone. Additionally, there is no easy way to create a thumbnail image if all you have is a gcode file. Inside Cura, you have the 3d model loaded and it is easy to create a view of that 3d model. Outside Cura, how would you make that image that you would include in the gcode in the first place?
