Great!! I like the blue/transparent combination.
Congratulation...!
Congratulation...!
Looks great!! Nice job.
Is the mix of laser cut wood in there functional or aesthetic?
My local plastics supply didn't carry a 4MM acrylic, so I used birch plywood (5/32 is essentially the same thing as 4mm), which I could buy from a local wood working shop.
With some of the wood parts, changing the thickness would change how things fit together, but others I could have easily replaced with 1/8 in acrylic, like the bearing covers on the outside. I was more concerned with getting it all together and working first.
As a note, these are the parts I had a pretty hard time sourcing or using substitutes:
I learned a lot building the machine, and I'm already working on another one, in red. That machine will likely include a heated bed, dual extrusion, closed in left and right sides (like the Ultimaker2), and a custom modified version of the PCB that uses different connectors.
Sir, please provide the DXF or CAD file which you utilized to build this awesome en-closer.
skint 61
Top Job ! Looks great.
