Hi @Joren365 by the issues you are describing it sounds like your xy is either out of alignment, or you have a loose pulley or you have a damaged endstop limit switch.
UltiMaker does not provide formal support via the community, I would recommend reaching out to UltiMaker support directly for help with your issues.
I would recommend providing the information you have provided as well as video and pictures of what you are seeing.
You can contact UltiMaker support here: https://support.ultimaker.com/s/contactsupport
1
Joren365 0
Did some more testing with cura 5.4 by exporting to a flashdrive instead of over cloud (which didn't made any difference) and observed every step it did. On the single color single part it all went fine.
Then I tried doing the 2-material part which I multiplied 15x or more. first it correctly calibrates both nozzle by pushing them both against the glass plate (it switches between them without issue). Then it starts leveling the bed with the 1e nozzle correctly. Last it switches to the 2e nozzle to do the 3 point level thingy correctly.
Now it totally gets lost. It moves back to the right side to lift the 2e nozzle but instead of aligning correctly it pushes the lever against the flat part of the U shaped lever grip instead of putting it right in between so it's not lifting the 2e nozzle at all. Then it starts printing with the 1e nozzle but at the previously mentioned 1mm above the bed again.
Now to confirm all this I took the same 2-material part and started printing it just once, not multiplying it inside cura. This time it does everything correctly as before AND it correctly alligns the printhead and retracts the 2e nozzle as its last step before actually printing (perfect).
I did the lift switch calibration under maintenance as well but that never made a difference. And small multi material prints worked fine nonetheless. I did bigger 2-material parts that i could multiply 3 times (2+ day print) to fill the bed before these prints without issue.
