23 minutes ago, Slashee_the_Cow said:"enough that around here we recommend people use 5.3.1 instead"
Out of curiosity: who is this "we"? I mostly see you saying this.
Cura 5.4 works fine for my prints. That does not mean that it does not have any bugs, but those bugs don't warrant a "don't use 5.4" response on every unrelated issue people run into.
1
Slashee_the_Cow 619
Are you using Cura 5.4? That has a few known slicing bugs. And by "a few" I mean "enough that around here we recommend people use 5.3.1 instead". So... try using 5.3.1 instead (you don't need to uninstall 5.4, they can be installed side by side).
Also if you could upload Cura project file (.3mf, go to File > Save Project in Cura) that would help with the detective work. Just the model file isn't much to go by when looking for problems in the print settings (though you provided something, which puts you as "more thoughtful than a lot of people").
