- Solution
That has more power than you need. The um2go doesn't come with a heated bed so you can use a lower value power supply. Actually I sell heated beds for um2go and you still don't need to upgrade the power supply (there's a trick if you want to use the smaller power supply and also a heated bed).
Anyway, here is the official power supply part information:
company: Mean Well
part number; GS120A24-R7B
If you are in USA I recommend digikey.com. $50.
Her school likely has the power supply. They just lost it. Maybe she can find it? Google it to see what it looks like.
1
GregValiant 1,342
One of the UltiMaker savvy folks will respond. @gr5 or at @Torgeir may have an idea where to get a regular power supply from. That "solid gold" one on Amazon is a bit much. The description states "240 input voltage" and "240 output voltage". My question would be "what's it really doing?".
You probably only need a brick that has the input voltage to match your home, and with the correct voltage-out and the correct male output plug to match the printer.
