Can confirm this. Out of our 12 UM2C's, four have network issues. Common response from the retailer; we would have to box up the machines and send them in for repair. I suspect a common design/engineering issue.
Switching to Bambu Lab.
Bambu Lab machines don't have ethernet which is annoying and I think the wifi is 2.4ghz only like Ultimaker. I am sure the wifi setup is much more straight forward on Bambu lab though!
gr5 2,177
Are they under warranty? A lot of things can go wrong in shipping. Perhaps the wifi antenna or something fell out and just needs to be reconnected.
I'm sure you can find someone to buy the S5s.
mrender 25
From experience S5 machines work much more reliably over wired ethernet with reserved IP addresses, wouldn't bother with wifi on these machines especially if you have more than one and use digital factory!
