I had this problem too. I got around it by moving the Gradual Flow plugin outside the plugins folder so it didn't try and load it.
- Solution
Ah! Then it might be: https://github.com/Ultimaker/Cura/issues/16941
The proposed fix is a band-aid, but since we've had multiple reports it might be worth taking another look.
Thanks for the updates 💪
Thanks!
Replacing that file did the trick :)
1
- 3 weeks later...
Hello,
Just following up on this thread as I am having trouble opening Cura Ultimaker 5.5.0. To answer your questions,
1. Nope
2. Nope
3. Nope
4. Nope
5. Nope
6. Yes! I tried 'run as admin' but it's the same
I'm also trying to share my logs but when I follow the path C:\Users\\<my username>\, I don't see an AppData folder.
Do you know why that is? What should my next troubleshooting steps be?
Please advise.
2 hours ago, cmart328 said:I'm also trying to share my logs but when I follow the path C:\Users\\<my username>\, I don't see an AppData folder.
It's hidden by default. Just enter %APPDATA%\cura\ in the address bar and that should get you there.
dubbeltrubbel 5
I reported this before? Hmm, perhaps I did, no clue :)
1. Nope
2. Nope
3. Nope
4. Nope :)
5. Nope
6. Yes! I tried 'run as admin' now anyway but it's the same
Attaching the log file.
and below is the (probably same) error info from when it crashes
Thanks
Error Traceback
Traceback (most recent call last):
File "C:\Program Files\UltiMaker Cura 5.5.0-beta.1\share\cura\plugins\CuraEngineBackend\CuraEngineBackend.py", line 335, in slice
self.startPlugins()
File "C:\Program Files\UltiMaker Cura 5.5.0-beta.1\share\cura\plugins\CuraEngineBackend\CuraEngineBackend.py", line 208, in startPlugins
backend_plugin.start()
File "C:\Program Files\UltiMaker Cura 5.5.0-beta.1\share\cura\plugins\CuraEngineGradualFlow\GradualFlowPlugin.py", line 51, in start
super().start()
File "cura\BackendPlugin.py", line 74, in start
if not self.usePlugin():
File "C:\Program Files\UltiMaker Cura 5.5.0-beta.1\share\cura\plugins\CuraEngineGradualFlow\GradualFlowPlugin.py", line 41, in usePlugin
return any([extr.getProperty(f"{constants.settings_prefix}_gradual_flow_enabled", "value") for extr in machine_manager.activeMachine.extruderList if extr.hasProperty(f"{constants.settings_prefix}_gradual_flow_enabled", "value")])
AttributeError: 'NoneType' object has no attribute 'extruderList'
Logs
Thread 0x00004250 (most recent call first):
File "UM\Backend\Backend.py", line 209 in _storeStderrToLogThread
File "threading.py", line 946 in run
File "threading.py", line 1009 in _bootstrap_inner
File "threading.py", line 966 in _bootstrap
Thread 0x00009b58 (most recent call first):
File "UM\Backend\Backend.py", line 189 in _storeOutputToLogThread
Thread 0x00002728 (most recent call first):
File "threading.py", line 320 in wait
File "threading.py", line 460 in acquire
File "UM\JobQueue.py", line 98 in _nextJob
File "UM\JobQueue.py", line 124 in run
Thread 0x000030b0 (most recent call first):
Thread 0x0000563c (most recent call first):
Thread 0x00000714 (most recent call first):
Thread 0x0000b270 (most recent call first):
Thread 0x000092f4 (most recent call first):
Thread 0x0000645c (most recent call first):
Thread 0x00005e80 (most recent call first):
Thread 0x000017d4 (most recent call first):
Thread 0x0000b050 (most recent call first):
Thread 0x0000a4fc (most recent call first):
Thread 0x0000a9e0 (most recent call first):
Thread 0x00004b88 (most recent call first):
Thread 0x00004afc (most recent call first):
Thread 0x00009e5c (most recent call first):
Thread 0x00001a94 (most recent call first):
Thread 0x00004154 (most recent call first):
Thread 0x0000a53c (most recent call first):
Thread 0x00004874 (most recent call first):
Thread 0x0000b004 (most recent call first):
Thread 0x000074c0 (most recent call first):
Thread 0x00002a98 (most recent call first):
Thread 0x00007b88 (most recent call first):
Thread 0x0000980c (most recent call first):
Current thread 0x00009f74 (most recent call first):
File "cura\CrashHandler.py", line 397 in _logInfoWidget
File "cura\CrashHandler.py", line 182 in _createDialog
File "cura\CrashHandler.py", line 86 in __init__
File "cura_app.py", line 177 in exceptHook
File "cura\UI\CuraSplashScreen.py", line 54 in updateLoadingImage
File "UM\Qt\QtApplication.py", line 584 in showSplashMessage
File "cura\CuraApplication.py", line 847 in _setLoadingHint
File "cura\CuraApplication.py", line 561 in startSplashWindowPhase
File "UM\Application.py", line 268 in run
File "UM\Qt\QtApplication.py", line 381 in run
File "cura\CuraApplication.py", line 850 in run
File "cura_app.py", line 239 in <module>
cura.log
Edited by dubbeltrubbelLink to post
