1 hour ago, 3dprntz said:what do you mean by this?
that cura should slice the walls in the same way?
Hi Gero,
The quality of the prints you shown is indeed not OK.
The CPE profiles have not changed in the 5.5 release, only the PLA, T-PLA, PETG and ABS profiles have been altered. The remaining materials are still work in progress. I quickly checked the retract settings of CPE. I assumed an AA0.4 nozzle with an 0.2mm layer height. The retract settings are 45mm/s retract and unretract speed with 8mm retract distance.
I cannot see any retract losses for these settings in a quick test print I did yesterday (0 to 10mm retract distance from bottom to top, print direction from left to right):
Figure: Retract distance scan from 0 to 10mm distance from bottom to top of print. Retract is on the left side. Unretract on the right side. So the retract settings seem to be OK for the CPE. You can even lower the retract distance from 8 to 6mm (which we probably do when we update the profiles for this material later).
CPE is a very moisture sensitive material, which can cause oozing during retracted travel moves (leading to under extrusion after a retract). You can try drying the spool and keeping it conditioned in a Material Station after having dried it: https://support.ultimaker.com/s/article/1667412438817. I hope this solves this issue.
Otherwise, please send me the project file and I will check what is happening in this specific print.
Concerning the walls, Bambu prints them in the same way as we do. However, we print the outer wall first to get more dimensional accurate prints, this can cause a less nice seam if retraction is not tuned properly. We print inner wall first in our Visual intent mode (not yet available for CPE). You change the wall ordering yourself if you want to try it:
Thank you for the reply and the test of the retraction settings.
The print images shown were printed with an aa0.4 nozzle and the engineering settings, ergo 0.15mm layer height.
We print 90% of everything with the engineering profiles. Since visual quality on parts for customers is also very important to us, we may try the profiles for visual quality more often.
The CPE roll was dried in a PrintDryPro3 before printing and then stored in the Material Station. Here, I think we are absolutely following Ultimaker's recommended steps.
Regarding the comparison with BambuLab: The printing sequence of the walls is not the same even with the "From inside to outside" setting.
Enclosed is a print image of a component with 2 outer walls. Here all inner walls are grouped and finally the outer ones. If the distance between the two outer walls is too large (i.e. if the component were larger), there is a retraction between the two red outer walls and there is either a blob or an under-extrusion in the outer wall.
The same part in the Bambu Slicer will be printed differently from the wall order. Here, the walls from the Inner Outer Wall are grouped first, then the walls from the Outer Outer Wall. There is no extrusion break between the outer walls, so printing defects due to extrusion irregularities are not visible.
Hey @Gero and @PaulKuiper,
I split off your discussion on wall ordering settings, to keep the focus of the original thread on newly introduced bugs.
Good luck with troubleshooting ❤️💪
3dprntz 4
