24 minutes ago, GregValiant said:"Is there a file for prusaslicer and any step by step instructions on how to do it please"
Probably not on the Ultimaker site.
I also use cura. Is it easy to do? Any step by step videos or instructions please
Hi. The script I created was for the E3 S1 Pro & don't think it works on the E3 V2. If you are using an E3 S1 Pro; The instructions for Cura running on Windows are further up the thread.
You can either use the file in that post or the one in the post below that adds some additional print data to the thumbnail when it's displayed on the printer screen
Ensure when you add the Post Processor it is the last one in the Post Processor list if you are using any others. Like in the post below
Can anyone tell me how to instal Thumbnail on chromebook
2 hours ago, pelapi said:Can anyone tell me how to instal Thumbnail on chromebook
Cura is not officially supported on Chromebooks and as such this may not be possible.
On 2/7/2024 at 9:05 PM, PartySausage said:No problem @PatateFree glad to see its worked you.
If anyone is interested I've modified the script a little & it should now also add the print summary data to the thumbnail preview & display a status message when the gcode is saved.
I've tested it with a few users, hopefully it will work for you
Will this work for the S1 also?
1 hour ago, liep9000 said:Will this work for the S1 also?
I would suggest testing it yourself. If it doesn't work then all you need to do is delete the script and no harm done whatsoever.
There is a post processor for the e3s1p provided in this thread at
I use that script for e3s1p all the time. Instructions for win and osx in posts above the one linked.
Top Posters In This Topic
17
10
8
5
Popular Days
Mar 26
9
Mar 25
7
Feb 18
7
Feb 19
6
PartySausage 17 posts
Slashee_the_Cow 10 posts
Madnamie 8 posts
jaysenodell 5 posts
Popular Days
Mar 26 2024
Mar 25 2024
Feb 18 2024
Feb 19 2024
Popular Posts
PartySausage
Glad it's working. The procedure is a little different under Windows Download the file Copy to C:\Users\<user>\AppData\Roaming\cura\<ver>\scripts Start Cura In
jaysenodell
I couldn't find clear docs to get this installed on my OSx-based system. So if anyone is looking for general steps... Download the file Copy to ~/Library/Application Support/Cura/<v
jaysenodell
AH! If you just change the path in your step #2, that works on OSx as well! And thanks to your modified script my little ender now has nearly meaningful displays when a cura s
Posted Images
GregValiant 1,345
