3 hours ago, jaysenodell said:Thanks! I assumed I was seeing this incorrectly and that the hardware should manage the calibration of the build environment leaving Cura a "simple volume" of known dimensions in which to operate
Some newer models (like the Ender-3 V3 SE) completely auto-calibrate the bed level and Z offset for you (there aren't even knobs to manually level the bed). The dimensions of the build volume come from a printer's definition file in Cura.
GregValiant 1,253
Natively, Cura does not use a Z-offset. You can add one by enabling the "Z-Offset Plugin" from the Marketplace.
Cura always assumes that "0" means "0" because where the build plate actually is in space it is impossible to tell. It's the users job to move the build plate into position so the "Z=0" (the bottom of the nozzle) exactly coincides with the top of the build plate. People use the word "leveling" but that's a misnomer. You are setting the "Initial Z" to zero.
I use a piece of parchment paper which means that if I had issues "adjusting the initial Z" then I could use the plugin to make an adjustment. If you use ABL then the adjustment is the Z-offset setting in the printer and there is no need to adjust it in the gcode by using the plugin. They are not "synonymous" but rather "mutually exclusive". If you try to use both you'll end up chasing your tail.
jaysenodell 13
Thanks! I assumed I was seeing this incorrectly and that the hardware should manage the calibration of the build environment leaving Cura a "simple volume" of known dimensions in which to operate. I have been playing with subtractive manu (CNC gcode) a bit before additive and there have been enough "that isn't the same" hiccups that I wasn't sure about this one.
Thanks again!
