9 hours ago, jaysenodell said:My understanding of the G92 is that it isn't supposed to MOVE the extruder but that is tells Marlin "please consider the extruder position is currenly X nd treat it as such". I believe Creality has overridden this behavior becuase ... why not? Do I properly understand G92?
You understand correctly. G92 tells the printer "<insert axis here> is currently at <insert value here>". Cura uses it to reset the E value to 0 every so often even with absolute extrusion on to avoid rounding errors snowballing into big problems.
8 hours ago, jaysenodell said:stick with with @Slashee_the_Cow's support object.
I'd love to take credit for that but @GregValiant actually showed me that trick 😄
jaysenodell 13
@GregValiant you can call me names publically. I am a self acknowledged moron. Look what I found in my Ocroprint "beforePrintResume" script...
{% if pause_position.x is not none %} ; relative extruder M83 ; prime nozzle G1 E-5 F4500 G1 E5 F4500 G1 E5 F4500 ; absolute E M82 ; absolute XYZ G90 ; reset E G92 E{{ pause_position.e }} ; move back to pause position XYZ G1 X{{ pause_position.x }} Y{{ pause_position.y }} Z{{ pause_position.z }} F4500 ; reset to feed rate before pause if available {% if pause_position.f is not none %}G1 F{{ pause_position.f }}{% endif %} {% endif %}
Of particular note the section labled "prime nozzle".
Upon remove (commenting) of those three lines all artifacts are gone. It still feels like I should use that section to print a starting line like cura does at the open of every print job, but for now I'm going to leave it well enough alone and stick with with @Slashee_the_Cow's support object.
Thank you all for the help.
