New Printer Stringy PVA
Go to solution Solved by gr5,
Posted · New Printer Stringy PVA
6 hours ago, gr5 said:
Isopropyl Alcohol is very inexpensive and easy to find in stores.  In the USA it is found next to the bandages (in supermarkets, 7/11s, walmarts, drug stores).
I don't know about the USA, but in Australia you can also find it in hardware stores where it will probably just be called Isopropyl. Often it's near the paint (and/or adhesive) sections because it's great for cleaning surfaces before you stick stuff to them. I got some that comes in its own spray bottle,
        • 20 replies
