If it's PLA I doubt moisture is the issue as I have 10 year old PLA, never stored in a bag, works fine.
What kind of printer is this? This kind of issue and the solution tends to be printer specific. It's tricky to build hot ends that don't get stuck.
Slashee_the_Cow 267
I don't think it's the problem, but it wouldn't hurt to try drying the filament a bit - I've had PLA which has been laying around for years work reasonably well, but not all PLA is the same. Popular trick if you don't want to buy desiccant or a filament dryer is to set your printer's bed to about 60°, lay the spool of filament on the bed, cover it with a towel and give it an hour or two.
Have you tried printing again or just that one? It would be a good test to see if it works fine up to a certain height like that one, but then goes bad again, in which case you can probably rule out the filament as a problem.
Looking at your project file, I see you're printing at 190° - most PLA I print at 200-210, although most manufacturers put stickers or whatever on the side of the spool with recommended temperatures, speeds and such. If that says 190, then that's alright.
