- Solution
I would point this discussion to official statements by BASF
https://forward-am.com/material-portfolio/ultrafuse-filaments-for-fused-filaments-fabrication-fff/metal-filaments/ultrafuse-support-layer/
Note the Q&A section at the bottom of the page.
Short answer, the ceramic support material is not sold in North America due to IP issues they are working on.
DD core's only purpose is for printing the ceramic material, I wouldn't advise doing this with the CC core.
As the Ceramic isn't technically sold in North America, no reason for the DD core to be.
But yes the CC+DD cores go together like AA+BB when printing Metal material.
As for using the DD cores on the S3 - I believe they should work.
But it's very much not recommended to print with Metal on the S3 due to a lack of an air manger - you REALLY want one.
The material off-gas isn't good for you - per BASF's own TDS
https://move.forward-am.com/hubfs/AES Documentation/Metal Filaments/17-4 PH/TDS/Ultrafuse_17-4PH_TDS_EN_v1.1.pdf
QuoteProduct safety Recommended:
Process materials in a well ventilated room, or use professional extraction systems. For further and more detailed information please consult the corresponding material safety data sheets.
- 1
gr5 2,176
Yes, CC and DD work on the S3 (but not on the much older UM3). Regarding metal expansion pack, all I know is what this says:
https://support.ultimaker.com/s/article/1667337928794
TheMainMan 0
Does the DD print core compliment the CC print core similarly to how the BB compliments the AA? I read the DD print core is for support and CC is for composite material.
If the CC and DD are indeed meant to be used together, but DD is not available in the US, what could one use to replace the function of the DD print core when using the CC print core in an Ultimaker?
