8 hours ago, GregValiant said:I checked the log file and slicing took 38 HOURS.
Try setting your Maximum Resolution to something higher than 1 femtometre.
I kid. As far as I'm aware.
@Firedawg75 I'm not sure about Mac, but on Windows you can have as many different versions of Cura as you want installed side by side, so if something's taking ages in 5.6, you can try in 5.5. On Linux you're not even installing them so it's just a matter of running a different AppImage. If you save your project as a .3mf in 5.6 (go to File > Save Project) and then load it in 5.5 it should copy all the quality settings from it.
GregValiant 1,345
5.6.0 can be a lot slower and I have no idea why. There are supposed to be improvements in 5.7.
There was a bug report on Github regarding a largish model that wouldn't slice. I checked it and there were no errors in the model. I set Cura to slice it. After a few minutes I walked away to do something else, and I forgot about the computer. The next day I was away from home. When I finally got back to Cura, slicing had completed. I checked the log file and slicing took 38 HOURS. (The "print time" was 18 hrs.)
