For @ahoeben's suggestion to work, you'd also need to set Top/Bottom > Top/Bottom Thickness to at least half your model's total height so that every layer is printed in a concentric fashion (assuming I understand the situation correctly, but with the cow-human translation going there's plenty of times I don't understand the situation).
It would really help if you could post a Cura project file (.3mf, get it ready to print then go to File > Save Project) or at least the model STL file.
Based on the screenshot it looks like your holes are pretty tiny - make sure you use the thinnest lines and shortest layers you can pull off with your nozzle (or switch to a smaller nozzle if possible).
Edited by Slashee_the_Cow- 1
ahoeben 1,951
You could set "Top/Bottom Pattern" to "Concentric".
