First of all, thanks for your elaborate reply!
I checked the usb-stick that I used to transfer the .stl file to my Ultimaker, so that I could post the exact file that I used. However, when I load that specific file in Cura it says 'Make sure the g-code is suitable for your printer and printer configuration before sending the file to it. The g-code representation may not be accurate.'
Because of this, I sliced it again. If I'm correct, all settings are the same as when I tried to print. In the attachment are both projects.
Also, I will do the levelling as you suggested, but that has to wait until the weekend. After that I'll try again!
1st Cura Project.3mf 2nd Cura Project.3mf
Edited by Biem1000Pressed enter too soon...
gr5 2,176
Printing PVA is another whole learning curve.
Yes, PVA can get water in it and it only takes a few hours on the back of the printer. Certainly a week on the back of the printer and it has completely absorbed water. I don't think this is the problem in your final print but we have to talk about it. It's not ruined - you just have to dry it.
When storing PVA I use a 2 gallon (8 liter) zip lock bag for each spool and about 1/2 cup (1/8 liter) of desiccant per bag. Get color changing desiccant (buying a liter of desiccant is quite cheap). Sometimes you can get 2 spools in one bag. The desiccant needs to be recharged when it changes color which for me is once every month or so. I do it in a paper towel lined ceramic bowl and put it in the microwave for a minute or so and then let it sit out and cool for 2 minutes and repeat about 5 times until it stop getting lots of condensation.
To dry PVA, unspool enough for the next print (cura shows you this amount in the bottom right corner) and sit that on the heated bed with the spool on top and cover the filament and spool with a towel (or similar). Heat the bed to 55C (if you go over about 75C you will soften the PVA too much and deform the portion touching the bed). Leave it like this for at least 3 hours - I like to do overnight to get much of the still-spooled filament but usually just 4 hours is plenty for the unspooled portion.
This is the ordeal with using PVA. Having said all that I don't think your issue is with the PVA this time but perhaps it was in the first photo.
Please post your project file - I think we might have to tweak your support settings. The project file will contain your model (your STL) and your machine profile, the profile you chose, and any overrides you changed. Also the position you placed your model and how you scaled it. Do "file" "save project" and post that file here. Certain models need certain tweaks to get the support to work well. PLA usually prints pretty well on top of PVA but not nearly so well the other way around and this is related to the "support horizontal expansion" parameter which helps the PVA reach a path to the glass bed. I want to see your project file before I make any suggestions.
Leveling is critical - I haven't used active leveling in so long that I forget if it even does left/right core calibration. I do manual leveling on my UM3 (and active leveling on my S5). When doing manual leveling you need to get the exact same pressure on the calibration card (or use an ordinary sheet of printer paper) for the left and right nozzle. If the left nozzle is tighter when leveling, then printing PVA onto PLA will not squish as much as desired. If the right nozzle is tighter to the paper when leveling, then the PLA will not squish very well onto a lower layer of PVA.
