I printed a simple calibration cube, rotated 45 degrees to test supports, and something very strange happened. I used the settings you recommended as well. You can see in the pictures that the top printed fine, but everywhere that I had support it seemed to under extrude and string. This almost seems like a slicer/gcode error?
12 hours ago, Adventurehill1 said:I printed a simple calibration cube, rotated 45 degrees to test supports, and something very strange happened. I used the settings you recommended as well. You can see in the pictures that the top printed fine, but everywhere that I had support it seemed to under extrude and string. This almost seems like a slicer/gcode error?
Wish I had a good answer to that (and if anyone has one, I'd love for you to jump in and supply it), but I'm not sure if there's a way to avoid that, in my experience it's an inherently PETG thing. If you have Support > Enable Support Interface on (and it usually is by default) try turning it off (assuming your support is dense enough that you can bridge the gaps, but unless you've turned Support > Support Density way down it probably is) and set Support > Support Z Distance to 0.
Yes this means you're removing the support right from the model (if you use a pattern like Zig Zag it shouldn't be too hard to remove) which might cause a scar, but it also means that the model is sitting directly on top of something rather than having a chance to sag down to support. And trust me, it's a lot easier to file down a line or two from removing support than trying to sand a whole layer to get rid of a support interface. Unfortunately power tools are cheating and you will catch yourself out (my Dremel, using the highest grit disc I have, at the lowest speed, will melt the plastic and deform it).
Drying your filament might also help. 'wet' materials can also cause unpredictable/worse printing behavior.
Edited by PizzaTijd- 1
1 hour ago, PizzaTijd said:Drying your filament might also help. 'wet' materials can also cause unpredictable/worse printing behavior.
Nice save! I have a filament dryer so I always forget that one. Materials like PETG or TPU are hygroscopic (they absorb moisture from the atmosphere) and when they're "wet" they really don't print as well because they're runnier and the extruder can't grab them as well, nor can the nozzle direct its flow as accurately.
- Some people store their filament in resealable bags and put desiccant in them - you can buy it by the bottle, and get stuff that changes colour when it's absorbed about as much moisture as it can. When that happens, you just need to put the desiccant in the microwave on low for a little while until the colour changes back.
- You could buy a filament dryer - I went for this option because I'm lazy and know I'd never get around to checking and "recharging" desiccant. Just turn it on and put your filament in there for a couple of hours before you start printing - many have little holes you can open to get the filament out so you can print it while it's in the dryer (you still need to give it a bit of drying time before you start printing).
Some newer (and often fancier) ovens have a setting designed specifically for drying things.
- Some microwaves do, but you don't want to put your filament in there, just desiccant.
- About all that's left is the cheater's way - heat your printer bed up to about 50°, lay the filament down on top and cover it with a blanket. Give it a couple of hours.
Something I wondered when I started using PETG and TPU was "how long will it last after I pull it out of its vacuum sealed (and moisture free) bag" or "okay, so I dried it, how long until I have to dry it again?". Answer's not so simple. Plus I'm really over-cautious. Depends on your environmental conditions - Australian summer, 100% humidity anyone? I'll trade you.
- Store in resealable bag with desiccant: it's pretty simple - unload the printer whenever you've finished printing with it and put it back in the bag. Should last long enough out in the open for any decent print. If it's properly dry, maybe a day or two, as I said, depends on environmental conditions.
- Dryer: I don't actually know because I haven't tried, but if I haven't printed with it within the last 24 hours or so, I'll give it a bit of time drying (because it's so easy, it'd probably last a couple of days being dried again) before I start printing (my dryer's display tells you the internal humidity). I usually print while it's in the dryer (and leave it on).
- Oven: Probably two or three days. Ask @GregValiant, he's the one with the fancy oven.
- Hot printer bed: It's not so great because while you need the blanket to keep the heat in, it also traps the moisture so it's not as effective as the other options. Should give you at least a day or two
3 hours ago, PizzaTijd said:Drying your filament might also help. 'wet' materials can also cause unpredictable/worse printing behavior.
Thanks. I have a filament dryer, but maybe I let the filament sit out for too long between drying. I'll try it.
- 3 weeks later...
On 2/27/2024 at 11:44 PM, Slashee_the_Cow said:set Support > Support Z Distance to 0.
Do you think I'd be ok to set the z distance to 0.2? The lack of a support roof seems to have cured my problem, but the support is difficult to remove.
9 hours ago, Adventurehill1 said:Do you think I'd be ok to set the z distance to 0.2? The lack of a support roof seems to have cured my problem, but the support is difficult to remove.
Can't hurt to try. Remember: small scale testing is your friend.
Slashee_the_Cow 303
Always convenient when I find someone using the same brand of filament as me 🙂
PETG is inherently stringier than PLA which does make it annoying. Though it's great stuff when you get it the way you want it (especially when you want to build something a bit flexible and nail the right settings, though that can take a bit of trial and error).
For plastic buildup on the hot end and nozzle, I would say: double, possibly triple check your bed levelling and Z offset. If there's even a tiny bit of a gap between the nozzle and the top of your layer, it's going to be more inclined to stick to the nozzle because it's touching the nozzle and not the plastic/build plate.
Now, as for your print settings, I'd recommend the following changes:
There's also just that due to its stringy nature, it will leave more strings behind than something like PLA, and that's unavoidable. But hopefully we can get it mostly blob-free.
Hope that helps.
