Change Support > Support Structure from "Tree" to "Normal" if a tutorial is using that because tree and normal support have many different settings.
And if you want to make all the settings show up, scroll to the top, click the hamburger button (the three horizontal lines, and yes that is its actual term) and click "All".
ahoeben 1,951
On the top of the second screenshot, you can see that that user has typed "support" in the Search... box.
You can also search directly for "Support Pattern". If there's a setting you use a lot, then you can choose to keep it in the set of visible settings when the "Search..." box is empty, by right-clicking the setting and choosing "Keep setting visible".
Some users will recommend you make all settings visible. I recommend you don't. Only use those settings that you often change, and use the search for the rest. You might also want to try the Tabbed Settings plugin which will show you the full list of settings per category:
