Thank you. I have tried manually leveling several times but I still have this issue. I was thinking of manually leveling but leaving more space by eye. But that seems wrong.
is your lift switch (which moves the right nozzle up and down) calibrated properly? This can be checkt by running the lift switch test in the printer. Possibly you've to run the lift switch calibration process.
Regards
gr5 2,181
Maybe do the manual leveling before doing the xy calibration. I don't remember if that's mandatory but I think that's probably the problem.
