GregValiant 1,254
This is odd.
I opened the 3mf in MS 3D Builder and it showed errors. Cura and PrusaSlicer both sliced the models as if they had errors.
I exported the models from Cura as an STL file and surprisingly the exported models don't show any errors in either MS 3D Builder or when uploaded to https://formware.co/OnlineStlRepair.
In addition, after clearing the build plate and then importing the "exported" models they sliced fine.
The bottom line here is that once again I'm clueless. I'll guess and say that something happened to the models during translation which caused them to slice incorrectly and re-translating the files fixed the error...but I don't know if that is true.
This is the report from the Formware site regarding the "exported" STL file. Everything is copacetic.
-> Analysed your file:
--> 0 Naked edges (?)
--> 0 Planar holes (?)
--> 0 Non-planar holes (?)
--> 0 Non-manifold edges (?)
--> 0 Inverted faces (?)
--> 0 Degenerate faces (?)
--> 0 Duplicate faces (?)
--> 0 Disjoint shells (?)
-> Repairing: 100.00%
----- Repair completed in 2123ms ------
-> Vertex count changed from 2391 to 2391 (+0)
-> Triangle count changed from 4794 to 4794 (+0)
The surfaces bothered to show up.
Edited by GregValiant
GregValiant 1,254
The models have errors. Mesh Tools picks out open seams really well (non-watertight) but finding "flipped surfaces" and/or duplicate surfaces is a challenge.
This is the file opened in MS 3D Builder. All three models have errors. Flipped surfaces and duplicate surfaces will cause a slicer to get confused and skip layers.
This is in PrusaSlicer. You can see that the layers are missing or incomplete.
Meanwhile, back in Cura, once the model is repaired (MS 3D Builder) it slices as you would expect.
