44 minutes ago, jaysenodell said:I'll ask a silly question: What if you printed it as "separate solids" with the track as solid, uniform vertial stack then glue the land solids to it like a puzzle? Not as sexy, but would likely be easier...
The Problem is when I print the track alone i can´t get it off the Support because the track is only one layer (0.4 mm) thick. It needs the Support because it is one multiple Layers and not just flat
jaysenodell 17
