Slash,
HUGE thanks and I will look into it. BTW, this is the headlight bulb "electric connections" rubber-ish cover that is no longer made for the 1961 bike I'm restoring. So far I feel this material is flexible enough to do the deed. Point being, and as you can probably see, it is rather small.
I'd love to leave out the support but so far have been unable to with the thing collapsing on itself during print. This thing does print perfectly in 95a.
And I might even try that filament that changes it's flexibility properties based on the temp you extrude it. Fun and games are on the horizon to full steam ahead!
I will keep you informed for everyone's future knowledge but I will mark this as resolved.
Again, TYVM, PDC
Slashee_the_Cow 619
Unfortunately while I seem to be the resident TPU weirdo I'm not sure I can offer too much advice since I've never tried anything other than 95A (not impossible to find softer, but not as easy as going to Amazon and ordering some 95A, plus shipping costs in Australia tend to be on the high end so I make plenty of use of my Prime membership).
I'd be very much looking at retraction first - specifically, avoiding it wherever possible (and maybe limiting it using Travel > Maximum Retraction Count and Minimum Extrusion Distance Window and/or increasing Travel > Retraction Minimum Travel). 95A is soft enough that it can get ground up if it goes back and forth through the gears too much (hence why I often opt for strings rather than a failed print) so I'm guessing softer is worse.
But just looking at layer 11:
That has 17 retraction moves (the ones in light blue) in not a huge amount of filament. A lot of them are very close together (in the support interface).
Layer 18:
15 retraction moves.
Or I could be completely wrong and it's something else entirely. Make sure you're printing at the right temp and slow enough (I usually set it to 20mm/s for everything).
