Hi @Torgeir
It started with a bad surface and then it got worse. I am printing with 225 degree and 100% pla feed. I will share the file tomorrow. Do you think it could be the heater? The prints stick but sometimes they don’t. But Most of the time they stick.
Regards Nils
Torgeir 243
Hi @Nils_007,
Welcome in here.
In your preference I'll see your printer are an UM 2E+, actually the same printer as I have.
This looks a little strange, actually both of your prints.
The last picture looks like the feed are to high and maybe the extruder temp as well?
Under such condition the filaments will spread out very much.
Do you have had any problem having the first layer to stick well to the bed?
Is this something suddenly happen or?? Any strange thing related to your printer might give further info.
If you'll share your Project file with us (go to file (in Cura when your model is present with your settings) then select "Save Project") and attach it here.
Then "someone" may further investigate your problem.
Thanks
Regards
Torgeir
