Whenever I see that pattern it's almost always related to the zscrew.
Did it do this from the beginning? Or did this gradually happen over many months/years?
I know you said you cleaned the z screw but sometimes you need to take it out. I believe it's attached to the stepper so it all comes out (not as hard to do as you might think but you have to get to the 4 screws that hold the stepper), put it on newspaper, spray with wd-40, clean with toothbrush, dry it off, put a pea sized drop of grease on it and then put it back together.
When you cleaned the z screw did you use a toothpick or something that gets into the cracks? Did you realize it's a triple helix and you have to get all 3 threads?
If you measure the distance of 3 threads on the z screw (one rotation) is that similar to the height that the pattern sort-of repeats? If so then on thread is dirtier than the other two. Maybe.
The issue can be with the nut as well but in my experience, cleaning the z-screw very well is usually enough.
As a test you can just clean the 4cm of z-screw near the top that is used for prints shorter than 4cm in situ (without removing). You can use a paper towel and a very small screwdriver and a friend to spin the z screw. Or put rags around/under the area and use a toothbrush and wd-40 (and paper towels or rags to dry).
Slashee_the_Cow 271
No. Where there's a discrepancy like that Cura will round it to (IIRC) the nearest multiple of either Quality > Wall Line Width or Quality > Wall Line Width ± Walls > Minimum Wall Line Width, depending on which is closer... or something like that. Either way, the important part is that it rounds it to something it can do.
If you could share a Cura project file like your example there (.3mf, in Cura get it ready to print then go to File > Save Project) that would help because then we could see all your settings.
Off the top of my head, about all I can think of right now is make sure you have Cooling > Fan Speed set to 100%, but given PLA is fairly temperature stable, I don't think that would be a fix.
