Hi glx,
Thanks for the reply. did a hot and cold pull prior to posting. All clear.
Also ‐ wierdly my printcore shows a max temp in the 200s
Appreciate your input.
I'm trying to troubleshoot a few things on this machine with partial success.
A
Edited by Andrew_F
glx 27
You could check if probably the path above the nozzle is partially blocked because of the previously failed cooling fan.
Btw. I have a printcore that says this (works fine tho):
