Here are the firmware recoveries I have. The ones with "R1" should all be for the older S5. Note the dates. Pick the oldest and newest (newest supplied from Ultimaker) This is a listing from my website gr5.org so just go to
https://gr5.org/insert_image_name_here.img
And it should automatically start downloading. Or create the link on a web page and right click and select to download.
If there is a newer firmware let me know and I should get off my butt and add it to the below list. Why UM hides the old firmwares, I don't know. They are useful.
-rw-r--r-- 1 grfivorg grfivorg 279969792 Jul 19 2023 UM3_recovery-3.7.7.20170627.img -rw-r--r-- 1 grfivorg grfivorg 332398592 Sep 11 2020 UM3_recovery-4.3.3.20180529.img -rw-r--r-- 1 grfivorg grfivorg 181449728 Nov 14 2020 gr-S5-R1.img -rw-r--r-- 1 grfivorg grfivorg 309789184 May 26 2021 um-restore-6.4.0-R1-gr.img -rw-r--r-- 1 grfivorg grfivorg 326318080 May 4 2023 um-restore-7.1.3-S5R1.img
gr5 2,330
So from your description I think you probably have bad blocks in your "hard drive". By hard drive I mean the SSD chip that serves as the drives for the linux computer.
The chip automatically detects bad blocks and routes them to new locations but the data in the bad block is lost so you have to re-install the software.
Sometimes the bad block is part of the formatting so sometimes you have to reformat one of the 3 partitions.
Sometimes the bad block is part of the partition table so you have to repartition everything.
Sometimes there are many bad blocks so you have to do the above steps a few times. Always there are excessive amounts of good blocks because we use maybe 1/4 of the SSD.
Most of the firmware installers are "too smart" and won't reformat or repartition unless the size has changed.
So I find the easiest way to deal with all this is to install 2 different versions that had different partition sizes. That way the firmware recovery sees the partition size is different and it has to do a complete reinstall.
I have links to a few of these firmware recoveries here: https://gr5.org/unbricking/
Okay I just checked the above link and for some reason I don't see very many S5 (any?) recoveries although I know I have some for sure as I've used them for my S5. I guess I'd try to get one from firmware 4.X and one from 5.X because somewhere in there they changed the partition size.
Or you can get an olimex cable and see what's going on step by step. Described in the unbricking page. Unfortunately the unbricking page is a mess. I have edited it maybe 30 times and it gets more confusing each time. Sorry. If you have an olimex cable you can repartition it to random partition sizes and then run the latest firmware recovery, it will be forced to repartition.
Basically - keep trying firmware recoveries. Try different ones to force them to repartion and hence also reformat each partition.
With the olimex cable you can also run connman (which sets up and controls the wifi and ethernet).
