7 hours ago, Slashee_the_Cow said:Also, if you're running it over USB: you shouldn't be. USB printing is deprecated and no longer supported.
Now hold on... Octoprint.
e3s1p and pauses don't always play nice nice. I could not get pause to work reliably from SD card. The problem is with the "custom" firmware not really respecting the proper commands. It seems to be a thing with the "pro" printers and that fancy interface. My solution was an octoprint server and running all my prints through that (which uses USB to control the printer hence my argument with the ever correct slashee). Using that, all the printer controls are on my phone or webpage making it no issue to resume the prints.
Slashee_the_Cow 619
Are you running the printer over USB or putting the gcode file on an SD card? If you're printing over USB then the control panel on the printer probably won't make it resume; the printer is waiting for the computer to tell it to resume. If you're printing from the SD card I've never had a problem with my E3V2Neo or E3V3SE resuming just by pressing the control knob, doesn't even have to be in the right part of the UI.
Also, if you're running it over USB: you shouldn't be. USB printing is deprecated and no longer supported. It's a relic from the days when printers didn't even have enough processing power to read from a memory card. It's more susceptible to flaws in the print (if something else is pegging your computer's CPU, it can be slow to send commands which can stall the printer and a nozzle sitting around waiting is a recipe for flaws) or outright failed prints (computers crash).
Also worth noting:
