fbrc8-erin 299
@DonMajime the complete kit is the Extrusion Upgrade Kit (part 9510) which is still available. It includes the updated print head, the feeder, the mounting plate you need to put a UM2+ feeder on your UM2, and the updated feeder motor you'll need--you can't run the geared UM2+ feeder with the knurled motor from the UM2. The kit also includes bed clips that don't hurt your fingers, and the print head shafts. But the feeder motor and the mounting plate are definitely essential to make the UM2+ feeder work on your UM2.
Like @Torgeir said, photos would be helpful since there might be other modifications on the machine worth looking at before proceeding.
- 2
Torgeir 273
Hi @DonMajime,
Welcome in here.
First, of course -you can use an UM2+ feeder, however you'll need a "complete" kit..
Before going this path, please share a picture here of your existing feeder, maybe things can have another way to be solved.
Thanks
Torgeir
DonMajime 0
I don't have my printer with me but it's juste that the printed feeder given by Cura that was used broke. Litterally the part that push the PLA broke in two piece.
Wdym by the complete kit ? I would need to buy other part if i want to use the UM2+ feeder instead of the original one ?
