I tried to edit/copy json defintions file but failed. Any hint or idea?
I have added some notes on UltiGCode to the readme of the plugin:
https://github.com/fieldOfView/OctoPrintPlugin/blob/master/README.md
Let me know if that works for you.
Not yet... the g-code startup and end procedures (RepRap) are missing and i can´t edit machine settings to add them manually. UM2+ starts printing in the upper left corner immediately without them.
ahoeben 1,963
Ok, I'll get cracking then... You might consider changing the resolution of the image served by mjpegstreamer though.
It won't be a very convenient toggle for now though. Switching is likely not going to be instantaneous.
No. The video stream is encoded as Motion JPEG (mjpg). This is basically full jpg images concatenated one after the other. If it were encoded with another codec (such as H.264), you would have a point.
