The benefit of lower baud rates is of course you are probably less likely to get all these checksum errors. Maybe.
I thought 9600 was the default and increased my chances for it working. I thought that was very slow, but oh well. I heard the motors burp and it could connect to update the firmware, so i was confused.
OK, i just set it to 250000 and get a lot of info when i click error log, it included:
Changing monitoring state from 'Connecting' to 'Operational'
Send: M105 T0
Recv: ok T:21.0 /0.0 B:0.0 /0.0 @:0
Send: M104 S200 T0
Send: M104 S200 T0
Recv: ok
Recv: ok
Send: M105 T0
Recv: ok T:21.1 /200.0 B:0.0 /0.0 @:127
Send: M105 T0
Recv: ok T:19.1 /200.0 B:0.0 /0.0 @:127
Send: M105 T0
Recv: ok T:13.0 /200.0 B:0.0 /0.0 @:127
Recv: Error:0
Recv: : Extruder switched off. MINTEMP triggered !
Changing monitoring state from 'Operational' to 'Error: 0: Extruder switched off. MINTEMP t...'
Recv: Error:Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
Does extruder switched off mean the stepper controller is bad?
Sorry I missed your post.
No. If the temp is lower than I believe 170C then the extruder is switched off to avoid grinding the filament. You can override this with a M command.
MINTEMP might be an error though - not sure. Probably not. There is also a MINTEMP ERROR but I think this log above just shows the normal extruder-switch-off flag.
gr5 2,070
9600 baud is very very slow for the arduino. The default for Cura is I think 110000 baud (or 250000 baud)- something like that. Approx 10X or 20X faster. Those are the only 2 speeds Cura works at.
If you must upload at 9600 then use pronterface which lets you set the baudrate to lower baud rates. You can get pronterface here:
http://koti.kapsi.fi/~kliment/printrun/
Also if you want to PRINT at 9600 as well you need to modify Marlin. The defaults are I think 110K baud and 250k baud. You can build your own custom Marlin here with a baud rate of 9600 easily:
http://marlinbuilder.robotfuzz.com/
However be aware that even at 250k baud, sometimes if the lines segments are really short (e.g. in the yoda head) even 250k baud is too slow to print "live". The USB just isn't as fast as the printer. For printing a cube, 9600 baud should be fine as there is only 4 line segments per layer (as opposed to typically 100,000 line segments per layer for something made from zbrush - like yoda).
