The difference is convenience (cool, it rhymes ).
With UltiGCode you get gcode that does not depend on the filament diameter. Usualy when you slice your model, you have to specify the diameter. With UltiGCode the diameter is saved in firmware (menu entry "Material"). Now you could slice a model and print it in different colors (assuming all your different filament brands have the same diameter).
To be honest I am a bit torn on this issue. Filament is rarely consistent reagarding its diameter. But then again if the fluctuations are small enough, they are negligible. I am printing nice models with only one material preset set to 2.9mm diameter... And since presets can't be renamed on the UM2 yet, and you can't select a preset in the tune menu - they are not that useful to me right now.
On the other hand OctoPrint ist extremely useful. Not only do you get a nice interface but your past prints are saved so you can allways come back and take a look at the print settings. It does allow you to track the printing time (vs. the calculated time - something that's a hit or miss issue with Cura).
I wish OctoPrint would do a bit more regarding logging and accountability. It could track for example how much filament you have left because it knows what you have printed. It could also allow rating/taking notes for finished prints so you can later search and re-print your best models (in different colors if it would support UltiGCode). It could automate the "I made one" feature for Thingiverse (or YouMagine) if you have a webcam.
So many cool features. But for now I'll stick with Cura/sd card/walking up to the printer. Since the dreaded filament strand always gets in the way when a print starts, I'll have to be there and snag it off. There is no fully automated click print and come back when done system yet.
DidierKlein 727
What is the difference that makes you so unconfortable with not using UltiGCode? I'm not very familiar with Gcode at all for the moment so i don't really now what it changes?
