That happens sometimes, and could be due to a partially higher water content in the filament, I suppose.
Markus
Markus
It's the filament rubbing on the extruded as it enters.
What fingerpuk said. I recommend putting the filament on the floor. This rubbing causes problems and slowly grinds up the black ABS plastic that the feeder is made out of and that ABS plastic gets dragged eventually into the nozzle where it causes serious problems in the nozzle such as blockages or reduced ability to extrude.
ecflam 0
nevermind, I unwind the filament roll a bit and the sound went away.
