Material feeder makes loud squeaky noise
ecflam
  • 3 weeks later...
Posted · Material feeder makes loud squeaky noise
What fingerpuk said. I recommend putting the filament on the floor. This rubbing causes problems and slowly grinds up the black ABS plastic that the feeder is made out of and that ABS plastic gets dragged eventually into the nozzle where it causes serious problems in the nozzle such as blockages or reduced ability to extrude.
Red spool
