By the way - even though it makes a horrible noise, it seems not to cause any damage. This has happened to me plenty of times (when homing on the left side - not the right side) and many many other people. The printer is designed to withstand this kind of abuse. Some people call it the "death rattle" when it happens over a few seconds.
gr5 2,330
Let's call this the "head".
Yes, maybe, but definitely will cause steppers to lose steps. Many steps. Causing the rest of the layer and subsequent layers to print in the wrong place.
The head is probably hitting the black block on the rod and not the rod directly, right? Is it possible the fan shroud is hitting the right wall?
I believe the spec is either 225 or 235mm in X travel before it hits the "software limit switch" in Marlin.
1) I had a similar problem where I hadn't noticed but there are 2 linear bearings near the top of the print head that the two rods pass through - one of my linear bearings was sticking out the side of the head a bit - I think I bumped it when I had taken the head apart and didn't line it back up when I tightened it again. Could that be it? If so you can see the metal cylinder that houses the bearing sticking out the side of the head a few mm.
2) Some people have had their fan shrould miss bent such that it hits one or both sides of the UM.
I recommend you donwload pronterface (it's free and easy to use):
http://koti.kapsi.fi/~kliment/printrun/
Connect your computer with pronterface up to the printer with USB cable, then command it to go to various X positions. For example
G1 X0
goes to postion 0 (left side)
G1 X200
goes to position 200
Then see how far it goes before hitting something (or hitting software end stop). Will it go to X225? X235? X240?
Repeat this with Y axis - one of the axes is 10mm longer than the other. Not sure which.
