Your print speed should improve drastically if you would move the feeder onto the extruder like here: http://umforum.ultimaker.com/index.php?/topic/3261-ultimaker-2-extrusion-problem/&do=findComment&comment=46577
I have seen how good flex materials are printable on machines with extruders that had their feeder directly built above them..... it limits your speed naturally but should improve overall speed with flex mats by a great deal.
gr5 2,229
Where does all the extra material go? Does it turn into a gas? Is the diameter 2.85mm?
Maybe it is slipping? It must be slipping. Try printing slower? Some people say you have to print as slow as 10mm/sec with flex materials. Some people recommend a drop of oil inside the bowden but I don't know how to get it in there!
