Do everything Illuminarti says but be aware that the most likely failure is inside the nozzle - the wiring gets stressed the most there. But if you have a multimeter, you can keep the meter hooked up and while watching it push and prod the wiring in different places until the resistance jumps suddenly to an extreme (e.g. 1,000,000 ohms or more, or less than 10 ohms).
illuminarti 18
Hi Steve. Sorry to hear that you're having problems.
Yes, it is mostly a problem that affects the bed, but if the error doesn't mention the bed, it's the hot end. Unfortunately, there's no way to know from the error message whether the issue was that the temperature was reading too high, or too low.
You might start by taking the large cover off the electronics under the printer, and checking if the cable is properly seated into the main board. It's the thin cables going into the TEMP1 socket.
If the attachment is ok, then you might try visually inspecting the temp sensor where it goes into the back of the nozzle block. Look for any signs of loose wires, or fraying.
If you have a multimeter, you could next try measuring the resistance across the temp sensor leads. With the power off, at room temperature, it should be around 108 Ohms. If you can get a good reading, then try moving the head around by hand, and measure in with it in different places. There may be a damaged lead that is causing incorrect readings as the cable is in certain positions.
There isn't currently a source of spares in the USA, but there have been rumors that UM plans to improve the support and spares situation on this side of the Atlantic before too long - but that doesn't really help you right now, I know.
