Posted · Error building Ultimaker2Marlin
Hi gang, I built the firmware from source a while ago, and wanted to try the latest, and after modifying my makefile, I get this linker error:
C:Ultimaker2MarlinMarlin>make build
CXX applet/Marlin.elf
applet/SdFile.o:(.rodata._ZTV6SdFile+0x8): undefined reference to `Print::write(
unsigned char const*, unsigned int)'
make: *** [applet/Marlin.elf] Error 1
Did I miss something?
(btw, I'm pointing to a copy of arduino022 for build)
    Sorry I can't answer you question directly. However, I can tell you that I used the Arduino IDE to rebuild the UM version of marlin (found on the UM open source page) without a problem. There is a pde you can open to build it in the IDE,
    You might give that a try.
    Hmmm, not sure what you mean. I just unzipped the Arduino IDE, open up the marlin pde, changing configuration.h and upload.
    I guess I don't understand why you are modifying the standard libraries. In fact, I believe the arduino IDE zip comes with everything you need and should only use the libraries from within it.
    I'm talking Windows 7 so that might be the difference.
    The Arduino IDE always defines the TWI interrupt, however the UM2 firmware needs to have this interrupt to it's own use. (For performance reasons)
    Kevin, I recommend pointing at an Arduino 1.0.1, and the Makefile might be missing bits&pieces. I'm using a Code::Blocks project to build the firmware myself.
    Woot! Thanks David, that did the trick. Apparently Arduino-022 doesn't work anymore
    As I stand before the same issue: Did I get you guys right there is no way to compile it with the Arduino IDE? I tried 1.0.5 and failed.
    Does anyone have a working cbp file?
    FWIW, I'm compiling it from the make file using the 1.0.5 libraries, basically using the same method as I outlined http://www.extrudable.me/2013/05/03/building-marlin-from-scratch/, for the Ultimaker Original firmware.
    I use the Makefile build. http://goo.gl/xSQnbc is my latest; it works with arduino 1.0.1 and firmware version 14.06.1 and 14.06.2. (Just noticed I need to update the arduino version comment at the top -- that'll be in my next pull request to Daid.)
    I'm using Linux, but don't know of any reason why it shouldn't work on other platforms. Since Daid doesn't use the Makefile, I intend to keep this updated in https://github.com/stevegt/Ultimaker2Marlin, and expect to continue forwarding pull requests upstream to Daid.
    I found a work-around with the Arduino IDE 1.0.5. I just moved the wire library into another folder where the IDE doesn't find it for compiling the fw.
