Thanks for the link, looks like more people are having trouble with the arduino board...
During the installation of Cura, all went well and the arduino driver was supposedly installed - no error message then.
I do get a sound when connecting the board via USB, and it does light up (green LED and orange LED at pin13):
However, only an unknown device pops up in the device manager. In the port section of the device manager nothing changes at all, so I can't get a COM number for the board:
Then I downloaded the latest driver from arduino.cc. When I try to manually update the driver for the 'unknown USB device', I get this message:
I found a thread online about how to temporarily disable driver verification in Windows 7:
http://en.kioskea.net/faq/3914-windows-7-disable-signature-verification-of-drivers
Did that as advised, tried to update the driver again, and still no luck.
Installing the arduino software and its drivers also could not get it to work. When trying to upload a test program to the arduino mega 2560, the communication fails or cannot be established:
Changing the COM port number in the arduino program made no difference.
Is this an issue with the arduino mega 2560 running under Windows 7 64bit?
What I don't understand is that it also won't recognize the board on my fresh dual-boot install of Ubuntu 14.04. To be fair, I have to add that I haven't yet tried to install the arduino drivers manually onto that system (Cura is of course properly installed).
It's a tricky one...
Hope you guys can help!
Cheers,
Fran
gr5 1,968
usb debugging (post #7):
http://umforum.ultimaker.com/index.php?/topic/5100-how-to-update-um2-firmware/?p=46156
Narrow down at which step you are having trouble by following the debugging advice in post #7 in the link above.
