I always set my temp to 0C in cura which means Cura doesn't do anything related to temperature so you can add your own temperature gcodes (there's one where it waits until it gets to the temp and another gcode where it doesn't wait) or you can set the temp before you start the print or whatever.
Dim3nsioneer 559
The lines on the top come from Cura. They won't be there if you uncomment lines 6 and 7 of the start.gcode. And then you can add other commands before these two lines.
