This picture for example, It's a thingiverse miniature. You can see the "problematic parts" in the red circles.
Is that a view problem, or are there really no supports.
Regards
Midgard
Regards
Midgard
Hello again,
first @Osgar: Thanks, that could solve the problem. Setting the angle back to 10 makes support on the parts.
But... right now i see this in the view:
It seems, that the last couple of layers are set out of the build room and misplaced from the other layers.
Whats this?
Regards
Midgard
Yes, sure.
I take this one from thingiverse:
http://www.thingiverse.com/thing:313371
Then i repaired it via Netfabb (it has several holes an degenerated triangles) but now, it should be fine. I have those behaviour also at other models.
BTW: I'm using the 14.03 of Cura.
The "layers outside of view" is a very old long standing bug. It might have been fixed in the latest RC:
http://software.ultimaker.com/Cura_closed_beta/
(It has to do with an G92 in the start code)
It's the basis to any bugreport; Ensure that you are using the latest version and (if there are any) you've tried the release candidates. If you are feeling especially helpfull & adventurous; also test it on nightly builds.
Well, first thanks for the lots of help.
I'll try the RCs now. Using the nightlies, I'm to excited for gettting and using the new ultimaker.
(I'm a software developer indeed on the java side of life, but running a nightly build is always a task of developing for me, so if i find something and have access to the code, i want to fix it) .
Perhaps later, when i'm getting more familiar with the printer, Phyton an C.
But now: getting the printer and making first steps with the ultimaker 2.
Regards
Midgard
Python is pretty darn easy to get started with. The C side of things is a bit more tricky, but most of the really hard stuf is on the math, not so much in the actual implementation of things.
More developers for Cura is always good
IRobertI 521
Showing a picture of what's happening would be helpful in figuring out what's going on.
