marzvt 0 Posted May 25, 2014 in taller prints print tilted The test robot didn't print tilted but the cup does and a nexus 7 holder also printed tilted. How do I fix this? Share this post Link to post Share on other sites
illuminarti 16 Posted May 25, 2014 in taller prints print tilted What sort of printer is this? Most likely you either have loose one or more loose pulleys, or the short belts are catching on the frame somehow. Please post photos. Share this post Link to post Share on other sites
marzvt 0 Posted May 25, 2014 in taller prints print tilted Share this post Link to post Share on other sites
profepaco 0 Posted May 25, 2014 in taller prints print tilted I cannot believe that... Share this post Link to post Share on other sites
gr5 897 Posted May 26, 2014 in taller prints print tilted Was it X or Y axis that missed steps? There are two main causes of missed steps. Loose pulley causes sudden shifts. Rubbing/friction causes gradual shifts like this. If it's a UM1 it's almost certainly the rubber belt rubbing against the wood frame - you can tell because it twists back and forth each time it changes direction. Fix by adding washers under the 4 black plastic spacers and possibly also taking the motor off and moving the pulley even closer to the motor (should be very close - about 1/2mm). If UM2 it's also usually rubbing pulley or belt but usually right at the motor pulley. In that case the only solution I'm told is to move the pulley along the shaft closer to the motor. Share this post Link to post Share on other sites
marzvt 0 Posted May 26, 2014 in taller prints print tilted I was totally a slightly loose hex. All fixed now. thanks Illuminarti Share this post Link to post Share on other sites
gr5 897 Posted May 26, 2014 in taller prints print tilted On the pulley? really? That's really good to know for future as someone asks every week almost. Share this post Link to post Share on other sites
