Try a newer version of Cura - a bug that causes surface bumps was recently introduced that is fixed once again here:
http://software.ultimaker.com/Cura_closed_beta/
Also 70mm/sec is fine for very large parts with long smooth moves, but with small tight curves like this you will improve quality quite a bit at 30mm/sec. Or even 20mm/sec. This is because the extruder isn't constantly speeding up and slowing down as it will never go below 10mm/sec (3 to 1 speed change ratio versus 7 to 1).
Dim3nsioneer 557
First thing to check is the layer view in Cura. If you see the steps there too it's a slicing issue and you probably use Cura 14.03.
If you say lowering speed to 70mm/s, what speed have you printed normally and at what layer height. If it is 0.2mm or even higher at speed 70mm/s then I would strongly recommend to lower the speed significantly as fluctuations in the flow are more likely at such high material flow (e.g. 0.2mm (layer height) x 0.4mm (nozzle size) * 70mm/s =5.6mm^3/s is rather high).
It seems to me you try to print some kind of four legged animal with standard Cura support. If you haven't yet, you may try Meshmixer support; you'll have much less troubles with removing the support and will need lesse material.
