Many bad prints in years past were because the fan blew on the nozzle tip instead of the part. The nozzle tip always gets some wind but if it gets too much you get underextrusion issues because it is colder than the heat chamber.
This was particularly a problem when Ultimaker was testing their new UM2 design (before it came out) and Cura changed the way the fan is turned on quite a bit - it now comes on slowly so that the PID temperature controller doesn't allow the head to cool too much when they first come on. Also there was an issue related to air bouncing off the glass and hitting the nozzle.
So the cooling of the white teflon part is instead cooled by the 3rd fan on the UM2.
3poro 9
I don't think the hot end is wasting nearly half of the fan output even in the worst case, as the fan is anyway cooling down the aluminum structure. As aluminum conducts heat pretty well, the lone extruder benefits from being the only heat-producing element in the print head.
However, I see your point and I'm quite interested in the topic especially due to the closed chamber I have built for my UM2. Because of the closed chamber, I'm now a bit less worried about additional fan noise in the print head, as high-frequency noises get fairly well eliminated by the dome I have built. For this reason I have decided to try one of these:
http://www.yeahracing.com/catalog/yeah-racing-hacktronic-tornado-high-speed-ball-bearing-25mm-htn304-p-3471.html
I haven't received mine yet, but I'll let you know about my experience once I have incorporated one to my UM2 print head.
