How to 3D print with cura on UM2?
zhonghello
Posted · How to 3D print with cura on UM2?
Hello everyone~
Can I 3D print with cura on UM2 ?
I mean if I can control UM2 for 3D printing with cura directly though usb just like pronterface, not from SD card
Anyone knows? thank you!
    Thank Didier and Dim3nsineer for quick answer~
    However, I think it amazing if we can control a 3D printer with a friendly user interface like fronterface.
    Also I think it convenient to solve some issues by moving XYZ axis a little, preheating, changing temperature, extruding though pronterface. But we can only print with cura... :-|
    And I think it great if wifi function can be integrated in 3D printer :-P
    Yes, Robert, you are right :-P
    I tried to use pronterface to control UM2 this afternoon, and it still work
        • 27 replies
