Well it had chewed the life out of the filament. I even had a fight with it removing it.
Here is a screenshot of the expert settings, I hadn't found those previously ...... (hangs head in shame)
Thanks for your advice its much appreciated ........... Its a dark art configuring the printer but I must admit I am enjoying it (even the frustrating moments)
illuminarti 18
Rather than a nozzle blockage, you may just have ground away the filament in the extruder, to the point where it could not grip it any more.
There are couple of things that you might try... firstly, slightly increasing the tension setting in the extruder - turn the adjustment screw anticlockwise to lower the white indicator piece down a little bit, and try again.
It may have been the retractions for all the infill that caused the problem; what do you have for your retraction settings in the expert settings panel?
Other things that I notice looking at your settings - firstly, the travel speed should be a lot higher - I generally use 250mm/s. And the top/bottom thickness should be a higher multiple of your layer height; you generally want at least 5 layers - so 1mm for a 0.2mm layer height.
